Minimum internet speed
This topic is closed.
  • Anth1
    • Apr 2015
    • 50
    Hi
    As the title what is the recommended minimum Internet speed I currently have about 6 meg wired. How well do these boxes perform wireless? Do I need a special wirles dongle thing or will one for a computer/ laptop do? If the later is ok how do I load the software drivers?
  • martin035
    • Apr 2014
    • 1308
    6 mb easily fast enough, wireless dongles can be problematic for best results use home plugs if possible. If you have to use a wireless dongle get the ones made for the openbox just search the bay plenty of them on there, if you get one that's made for the openbox then the drivers are part of the firmware.
    • Anth1
      • Apr 2015
      • 50
      Thanks I was told I needed minimum of 10 Mbps. I thought that was rubbish
      • martin035
        • Apr 2014
        • 1308
        You would only need that speed on an openbox if you had the v8s and wanted to stream online HD content via the boxes WebTV feature.
        • Anth1
          • Apr 2015
          • 50
          Mines the v5 s
          • Hadron
            • 2102
            The Skybox & Openbox boxes are only compatible with dongles that use the Ralink RT5370 chipset.
            I have used this tiny one with no problems http://www.ebay.co.uk/itm/3213882333...%3AMEBIDX%3AIT
            My router is at the front of the house & the box is at the rear of the house. It worked perfectly for me, even though it doesn't have the massive aerial attached to it like the official ones have.
            • staden321
              • Nov 2015
              • 73
              I tether my phone for Wi fi to box it can pick it up through 2 walls outside and still works ok. As for speed they use a miniscule amount of data so 6 meg is more than enough all your doing is keeping it connected, like a bridge if you like
              Sent from my SM-G850F using Tapatalk
              • Anth1
                • Apr 2015
                • 50
                Thanks just proves I've been told a load of rubbish
                • staden321
                  • Nov 2015
                  • 73
                  Wat box you using???
                  • Anth1
                    • Apr 2015
                    • 50
                    I'm using the v5 s
                    • staden321
                      • Nov 2015
                      • 73
                      I got v8 so same really you don't need any special dangle ,all this 2 chip talk is nonsense. You can get them online or maybe even maplins, it's just usb with aerial on it don't try it but it would probably work if you stuck a coat hanger in it .
                      • Anth1
                        • Apr 2015
                        • 50
                        I'm using wired lan but have issues.
                        But thinking of getting a box for bedroom but this would be wireless
                        • staden321
                          • Nov 2015
                          • 73
                          As long as your router is Wi fi as well it would be no problem just go network setting, click Wi fi box will probably reboot, then down one to Wi fi manager click then you will see a list of available servers, pick yours,enter password it will connect, if you need any further help message me. Hope it goes ok
                          • Anth1
                            • Apr 2015
                            • 50
                            It's connected at 6 meg so my issue must be server related thanks
                            • staden321
                              • Nov 2015
                              • 73
                              Do you mean your lines not working
