Hi with these open boxes work ok on the same dish as a regular sky box?
Open box
Yes, if there's a free port on the LNB then run a sat cable from there to your openbox, you can leave your $ky box connected it will still work.
Or if you want the openbox and $ky box working in the same room, then disconnect one of the feeds to the $ky box and configure the $ky box for a single feed, Google search how to change the setting, then connect the free feed to the openbox, you will lose the ability to record on the $ky box but will save you money.Comment
