Help needed with Openbox V8S
  • Jim2308
    • Feb 2016
    Hi All,
    Im sure this question has been asked 100's of times but im not able to see anything when searching the forum, is there anyway to watch Saturday 3pm Kickoffs ?
    Thanks in advance
  • martin035
    • Apr 2014
    • 1308
    If your v8s points towards 28e ie $ky UK, then the only 3 clock kick off available is via Setenta SD/HD an Irish channel that shows 1 live match at that time. There is however other satellites that show more matches you just need a motorised setup or perhaps try an IPTV stream.
    The v8s via it's WebTV facility is capable of playing these steams but from reading past posts on this forum most members seem to have given up due to it been to difficult to find the streams then edit them for the v8s.
    • Jim2308
      • Feb 2016
      Thanks mate, no worries will stick to an app i have on a different device was hoping the openbox could do it but no problems cheers
      • middots3
        • 194
        Like Martin said, best bet is IPTV or i personally use Kodi. You'd be surprised how many HD streams there are.
