Openbox S12 Clone safe
  • mini
    • 602
    can somone point mr in the direction of the Openbox S12 clone safe firmware pls.
  • mini
    • 602
    Are the s9 s10 s11 s12 all same? do they work on each other?
    new to openbox prefer dreamboxes.
    • martin035
      • Apr 2014
      • 1308
      From searching the web it looks like Feb 2012 was the last release of any firmware for the s12 whether a clone or not, therefore there's a good chance your already running the latest firmware.
      • mini
        • 602
        the firmware i installed crashed the box (clone bomb).
        • mini
          • 602
          I downloaded the firmware by Anonymous, it doesnt have any sat list also for some reason it doesnt let me upload tp list either. It say tp list corrupt. But if I use s**box firmware I can upload the same tp list without issues, only problem clone bomb.....
          is there clone safe with sat list set up?
          • mini
            • 602
            got stable firmware but cant view channels for some reason, due to forum rules it cannot be discussed either.
            • P&D
              • May 2010
              • 2686
              Are you getting the FTA channels ?
              • mini
                • 602
                yea, all apart from channel 5. everythinf seems to work apart from **cam, which shows online.
                its all ok on my dm500
                • P&D
                  • May 2010
                  • 2686
                  What are you getting on screen No signal or scrambled ?
                  Go into the setting make sure DHCP is on & reboot the box.....see if that sorts the problem
                  • DW190
                    • May 2012
                    • 1263
                    If that don't work try a fixed ip in the range of your router and change the DNS to Googles. 008 008 008 008 Alternate 008 008 004 004
                    • mini
                      • 602
                      tried both, dhcp on/off 2 different routers. scr***led
                      • DW190
                        • May 2012
                        • 1263
                        Have you tried changing the DNS?
                        • mini
                          • 602
                          It does show my thing is online with a tick next to it.
                          nope did not try DNS, I'll give it a go later.
                          • mini
                            • 602
                            It's working
                            I didnt have to change anything, all I did was used the dm500 looped the output to the S12. Still not getting few channels like ch5, I've made a no signal fix using a diode but still not getting some channels. The major ones most seem to be working
                            • mini
                              • 602
                              Been playing baout wiv it and it only works when i connect it through the dm500. Otherwise none of the channels work. I tried the sat feed direct, the same one i use for dm500 and it didnt work, even using the diode fix. This box is b****cks. Dm's are the best. This has truly got me confused.
                              Any thoughts people. All help is much appreciated
                              Thank you
