F5S channels not clearing and more lol
  • johnski
    • Jan 2014
    • 11
    so ive added the necessary, but the channels arent clearing, i can download the epg (through ehternet) so i know its connected to the 'net......despite my router showing an orange led, got a constant green and flashing orange on the back of the box, the line is showing as offline but has a tick beside it, i know the line is active as ive trie it on my duo, what obvious thing as i missing?
    ps the orange led on the router turns green when i use the same cable and port on the duo, its only orange with the F5S
  • mini
    • 602
    is the DHCP off on the box if so switch it on.
    or try switching router off and box off, switch router on and wait 5mins then switch box on, could be ip conflict.
    • johnski
      • Jan 2014
      • 11
      tried with DHCP on and rebooting the router, i''l switch the router off for 5 and see what happens
      • mini
        • 602
        just to be sure try a different network cable also.
        what firmware is on box, is it factory? or have you re-flashed it?
        • johnski
          • Jan 2014
          • 11
          ive tried a different cable
          flashed with 2015981115824893 today, believe thats the latest
          • P&D
            • 2686
            Sill question but are you using the same "necessary part"
            on both boxes at the same time ?
            • mini
              • 602
              What P&D means is keep one box disconnected and try the other, most of the "PERSONS"offering service only allow one box at a time...
              have you got a backup of original firmware, flash that back and try that.
              • johnski
                • Jan 2014
                • 11
                no, the other box is turned off wheni try the sky box
                no backup, box was in the loft for over a year so things have expired and frequency's changed etc
                im sure its not connecting to the router proberlly hence the orange light on the router but it managed to download the epg
