Martin v Joshua - Information
  • cwaite
    • 360
    You can watch the fight ONLY if your provider has purchased the fight (if the channel shows $crambled during the event your provider has not purchased it)
    What channel number is it on?
    If you have CWAITES Latest list you can find it on Channel 491
    If you have AJ's Latest list you can find it on Channel 537
    If you get Invalid Program, Search again! Or No Signal when you tune to these channels then you do not have the latest channel list, Update your channel list. If you have updated your channel list and still get the message No Signal, please unplug any other Satellite boxes from the mains (do not just put them in standby) and see if that fixes the problem.
    If your not sure how to update the channel list check out this video on youtube:
    What frequency is it on?
    12148 H
    10876 V (HD Version) - Its very unlikley the HD Version will work, at present the channel is not even broadcasting, its likely to be switched on just before 6pm if you want to try.
    Can I see it in HD?
    Doubtful, you can try channel 492 on CWAITES list or Channel 536 on AJ's list but its very unlikely that it will work (at the time of writing this the HD channel is not broadcasting its currently showing Invalid Program, Search again!, its likely to be switched on just before 6pm)
    How can I be 100% sure I will see the fight?
    Purchase the event officially from Sly and watch on an official Sly box.
    What time is it on?
    The Event starts at 6pm (UK Time) but the main fight will probably start around 10:45pm (UK Time)
    If you need help installing channel guides or have a problem, take a look at my video guides
    https://www.youtube.com/playlist?lis...GHAAdpsKXqtadC
