X5 Channel List
  • inaminute23
    • Sep 2013
    • 16
    X5 Channel List
    Hi, does cwaites or aj's channel list work on the x5 box? Is it the same install procedure as the f5, v8s, etc?
  • mini
    • 602
    No they are not compatible, X5 file is .bin format
    the other boxes are .dbs
    but the procedure is the same.
    1 ... Unzip the file and save the DB(00000004).bin file to a USB Stick.
    2 ... Insert the USB Stick into the front USB port on the OpenBox X5.
    3 ... Press Menu -> Edit Channels -> Load DB and load the DB(00000004).bin file
    • inaminute23
      • Sep 2013
      • 16
      Cheers mate, but where will i find the channel list?
      • P&D
        • 2686
        Hi here you go but they are Aj's list dated 4-8-14
