Openbox V8s Upgrade by Network
This topic is closed.
  • summerhouse
    • Apr 2016
    Hi Im trying to set up openbox for the first time and not getting anywhere. I've downloaded channel list using usb, entered other info needed but channels still scrambled.
    I saw you could upgrade channel list by network in network local settings. Tried this it stayed at 0% and came up with message
    HTTP SERVER Error
    What does this mean ? Could this be the reason I'm getting nowhere ? I've looked in Network setting and it says Ethernet active I changed to WiFi and that said active.
  • mini
    • 602
    Download new list from ajsat.co.uk, if you have the lan tool use that to transfer tp list to box.
    OR
    copy list to USB then plug it in box and transfer.
    Also have quick look in forum, all these issues have been covered numerous times.
    • Hadron
      • Nov 2012
      • 2102
      If all of the $ channels are scrambled then it's a "gift" issue or a network issue.
      Try using the weather app, or try downloading the XMLTV EPG to see if you're connected to the internet.
      The "ethernet active" icon is simply showing that you have chosen ethernet. It doesn't mean that it's actually connected.
      • mikeon11
        • Jan 2012
        • 18
        HTTP SERVER Error
        It looks like your network is not active. make sure it is properly setup and running before anything else
          And no server talk allowed mate
          • summerhouse
            • Apr 2016
            Thanks for your help. Deleted channel lists etc turned off openbox, rebooted router and started from scratch. Sorted got all the channels. That was last night.
            I updated channels using network which was really easy. It rebooted itself when it had done it. Problem this morning after turning it on is all channels have disappeared. Anyone else had this ?
            Downloaded again no problems, when it's finished it doesn't give an option to save. Should I go elsewhere to save channel list?
            • tulalea
              • Jun 2013
              message superslytv on facebook they are good help
              • middots3
                • 194
                They are blatantly ripping people off. ?165 for zGemma boxes with ?10 gifts is ridiculous.
                • staden321
                  • Nov 2015
                  • 73
                  A reliable server is worth more than the price of openbox gifts are worthless
                  • Johnner
                    • 7069
                    Okay guys...I think that's enough here...I would refer you all back to the forum rules,which you obviously haven't read yet..
                    Forum Rules
