Invalid Program - Search again
  • durhamwasp
    • 12
    Totally randomly, I turned my skybox on the other morning, and found nearly every Finnish channel had the above message, I checked TPs and all correct, with signal strength on my box being 85-90% like normal.
    A bit of box on/off, waggling cables etc and eventually they started working again.
    Then its happened quite a few times since, sometimes I can be watching Finnish channels (0.8w) for hours, flick to a sky channel (28.2e) then go back to 0.8w and suddenly the channels on 0.8w are invalid.
    Any ideas? Im using a Switch (just replaced it) with dishes on 28.2e and 0.8w.
  • cowbridge lurcher
    • Dec 2014
    • 29
    could it be wifi ? try the latest channel update cwaite maybe ,
    • DW190
      • May 2012
      • 1263
      Dish Alignment, LNB or Cabling.
      • digicon
        • 8261
        Sounds like it could be another switch problem, do you have a spare you can try
        • durhamwasp
          • 12
          I just bought a new one, swapped it over and still same issue. Some days can work fine, others not.
          Process of elimination means it must be LNB or cable I guess. Cable is joined midway, LNB is about 10yrs old.
