virgin media box
  • cole2006
    • Feb 2010
    • 12
    virgin media box
    i have openbox v8 but i have cable what box do you use? id have sly to
    Not that one plus i do hope you read the rules regarding line talk .
    • joe516
      • 1000
      Originally posted by cole2006
      i have openbox v8 but i have virgin media line what box do you use?
      posted elsewhere to give people info of whats out there,if buying do research and see what back up the units have like support. MIRACLEBOX PREMIUM MINI HD e2 box can run vix and abm ?149 Q5 HD PVR mentioned as a weak tuner. reported hdmi does not work on panasonic,sony and philips tvs Openbox C4 Amiko Mini HD reports of some
      • P&D
        • 2686
        Come maca only give the member a break they only joined in 2010 & not had chance to check the rules out
        Bought a VM **what's it **.....for the openbox....I see lots of question's soon
        As for the boxes joe516 points out that should be fun
        Joe no disrespect intended great link
        Again NO offence to the OP ........If you buy a VM ** what's it** for the open box
        you may struggle with the boxes Joe points out they are defo not plug & play mate
        • paul93
          • 50
          need some help i had VM service before and skybox V8 was working perfect with home plugs now i changed to sly and slybox V8 is working perfect but my friend had VM and VO+ box working perfect now he changed to sly and home plugs are not working and direct ethernet from router to vo+box not working at all any help would be appriciated
          • cactikid
            • 12017
            if he had a cable box before and now lost the live feed,sly bb would be of no use as cable boxes need a cable feed to scan on and any internet provider.
            • paul93
              • 50
              it was with the dish no cable
              • paul93
                • 50
                yes it was with the cable before but now its with sly any solution for that
                • P&D
                  • 2686
                  I think you should ask the question again....your posts make no sense
                  Cable *what's it* is for a cable box
                  Sat *what's it* is for a sat box
                  You cannot use one on the other
                  • paul93
                    • 50
                    its was 100% sat box not a cable box sir
                    • paul93
                      • 50
                      VU+ sat box was running perfect with VM broadband but now with sly broadband home plugs not working and neither direct Ethernet cable from router to the box urgent help needed.Thanks in advance
                      • cactikid
                        • 12017
                        you did a network test on box and no connection? try powering off box and router as its a common fix.
                        • paul93
                          • 50
                          Thanks it worked
