Openbox V8s freezing on sky channels
  • lanesta83
    • May 2016
    Hi I have recently purchased a open box, all the standard or normal channels work fine. The sky channels freeze sometimes, only for a few seconds. Anyone had, or have this problem?
    I have sky fibre broadband which runs around 38Mbps when tested.
    The support form the guy I bought it off has been great, I have tried a few things he has suggested but still seem to have this freezing issue.
    Thanks,
    Nick.
  • P&D
    • 2686
    Are you using wifi or home plugs.....or wired ?
    • Superswallow
      • May 2016
      • 11
      I get some pixilation/freezing on some channels and put this down to the "nature of the beast". I use BT fibre optic Broadband which is quite fast so not sure that is to blame. Standard Normal channels are usually ok too.
      • chris31560
        • Feb 2010
        • 912
        m8, P@D asked if your using the wifi option or hard wire,, there is a reason for the question....
        A LITTLE THANX GOES A LONG WAY
        • Superswallow
          • May 2016
          • 11
          To Fully answerr P & D. I'm WiFi
          • P&D
            • 2686
            Wifi .....That's why the picture is crap.....Go & get some home plugs ?20 from PC World....or the bay
            • DW190
              • May 2012
              • 1263
              Had a few of these, quite good for the price. Only come with one Ethernet, why? I don't know.
              http://www.ebay.co.uk/itm/New-Bt-Arc...wAAOSwdWBXOc5B
              • Proz
                • Sep 2009
                • 22
                Stupid question time ..... Am i correct in thinking that the homeplugs have to be plugged directly into the wall socket and wont work plugged into an extension cable ?
                • Bigg93
                  • May 2016
                  • 5
                  It will work in an extension lead however they do recommend directly into the wall
                  • fox1562
                    • Feb 2010
                    • 17
                    It could also be that the gift you have on your box, which links to a sever has 1000s of other people, Checking the E.C.M = ( electronic counter measures ), Hence pixilation / freezing. But Thats is Normaly the problem, There may be a problem with your router via the Wifi. Ive been in the game for a nunber of years, When i brought out the blocker in the 80's.
                    There are some very Cheap Gifts Lines on Ebay ?15 - ?25 ALL CRAP TRUST ME & Many go off within 3 months if your luckly... Many people what Cheap Gifts Lines "Hence Crap" When the premier league starts again, Stop Start..Stop Start... Though out...... If you want clean viewing, contact ....******************** He Has the Power to Turn You On or Off.
                    • PremierD
                      TAMINATOR
                      • Jun 2009
                      • 13132
                      You've been here long enough to have read the rules mate .....
                      • staden321
                        • Nov 2015
                        • 73
                        Don't buy of flea bay look on forum and get month at a time unless you know or trust server
