cant save modified cwaite channel table created on MediaBox Editor Studio
  • charlie567
    • Mar 2013
    • 50
    Hi There
    I have been looking into modifying the cwaite channel table - just a few minor changes for sports and the lineups. I know it can be done in the openbox channel edit/favourites option but as its for a few friends, l thought it was made it easier just to make the changes and then email them the file.
    I have watched the tutorial which has been posted in the sticky section.
    Once l have edited the TP_PROG1.abs file (moved the channels as l want them), l select export file (from File), select the option Ali Generic NoCAS - Export
    Save File as:
    File name: TP_PROG1.abs
    Replace file: Yes
    Export only selected channels? No (tried yes as well - makes no difference)
    Export complete
    When l check the file in the directory it hasn't been updated (TP_PROG1.abs) but another file has been created:
    TP_PROG1_List01.abs
    When this is changed to TP_PROG1_List01.dbs and open PVR800-Editor - load the file - no changes are made.
    This is doing my head in - so any help on saving the edited TP_PROG file would be so much appreciated.
    I have used the program on Vista and Windows 7 - but still joy
    Really appreciate your help guys
    thank you
    Charlie
  • charlie567
    • Mar 2013
    • 50
    I am moving channels from the favourites categories.....is that the cause of the problem....
    That was the cause of the problem - thanks to bbb_uk for this tutorial
    How to Import/Export Openbox/Skybox channel list (.dbs file) in MediaBox Editor Studio Things you will need:- You will need to download and install MediaBox Editor Studio. (http://www.digital-kaos.co.uk/forums/downloads/tools/37/mediabox-editor-studio-v1-10-2446/) The first time you use this you will need to change the
