Hi peeps i've had the openbox V8s a week quite like it i was thinking of getting the ZGEMMA H.2S for twin tuner until i read on your forum the SD picture on the ZGEMMA was worse than the openbox anyone else seen both boxes in action to compare
ZGEMMA H.2S v Openbox vs8
I am only a casual user not an expert, but I can say that I have had both and could not really see any difference. But z-gemma is quite a bit more difficult to set up if you buy a bare box but with a bit of searching you will soon find help and save your self some dosh. Very smooth box with record facility - great! -
No, if you use a supported firmware ie Openatv then once you've flashed the image on the zgemma, all other updates are done over the air and don't require reflashing
It's automatic via a program (plugin) added to the Zgemma most use either Autobouquetmaker or AutobouquetsE2 these plugins are available from the Zgemma's plugin menu on the remote.Comment
