openbox v8s problems
  • razman1888
    • Jul 2016
    Hi im using an openbox v8s im unable to update via network settings internet working ok also unable to do a channel update via usb stick in tools section is shaded not allowing access can some one point me in the right direction thanks.
  • Ronnie Ainsdale
    • Oct 2015
    • 11
    When you insert a USB stick into your box, front or back, you'll get a box appear on screen stating USB A or B connected. Then your shaded values in the menu are accessible. If your USB doesn't connect try another stick.
    If, when you try to update by network, you don't get the red 'connect' box appear then you've either got old firmware or a clone box!
    • steaker
      • Apr 2013
      Hi. Just wondering if anyone has ever had a problem with one channel on there openbox. I have a certain channel that won't work but everything else is ok? Any suggestions of how to fix this? Tried Channel list update and a rescan but nothing. Any help would be appreciated.
      • ayam100
        • Sep 2014
        Hello there, try to download from this website , them have 2 version one is old version one is new version http://www.openbox.cm
        good luck
        • freadthehead
          • Apr 2010
          • 10
          I have had the same for some reason the v8s on some boxs don't like the xxxxx the only way I fixed it was to change the xxxxx to xxxxx
