Boxnation
  • DL1982
    • Sep 2012
    • 104
    Boxnation
    My boxnation is all sound no picture,does it need reflashed or can I type in another frequency and get it working.
    Thanks DL
  • PutTheFootieOn
    • Feb 2014
    • 75
    You will need a later firmware if its very old, had that issue myself as did others, 2014/12/04 firmware or later (if F5s) sorted it
    • P&D
      • May 2010
      • 2686
      A bit more info what box would help.......
      what firmware you have on the box ?.......in the menu system info FM ware
      the more you can tell us......will help to answer your question.....otherwise we all are playing a guessing game
      In the older model F3/5 try the V.Format button..........
      the answer could be lots of things
      channel list out of date
      HDMI cable
      TV set on the settings
      In you have the scart plug on the back of the box.......try a scart lead......see if it fixes the problem........if so TV setting wrong
      are the rest of the channels ok
      Again the more info you give us.......much easier to point you in the right direction
      • DL1982
        • Sep 2012
        • 104
        It's a f5 box,every other channel is working fine except this 1,I will try all those options and hopefully 1 of those sorts it out,thanks for your help.
        • Hadron
          • Nov 2012
          • 2102
          If it's old firmware, then there will be a few other channels with the same problem.
          Some of my channels on my f3 have sound but no picture,anyone encountered this problem?
          • intel
            • Apr 2010
            • 128
            Its your firmware...............just needs to be updated, then you will get the picture to go with the sound..
