Couple of Openbox questions...
  • lewdsnarler
    • Aug 2016
    • 6
    Hi Everyone...
    Am ordering an Openbox V8S this afternoon, got a couple of questions I wanted to ask... Just knocking Sky on the head, dunno why but everytime I watch they have an Ad break, and when you flick channels they sync the ads to them all. So I thought I'd try Freesat. So here goes...
    (1) The EPG. - Been looking at YouTube videos... And it looks like you can only see Now and Next Programmes... Any way to record for up to 7 days?
    (2) Adding a Hard Drive for recording... Do I format it to FAT32? Isn't there a 4GB limit on the files? And does this create issues for HD shows? And will a portable 1TB drive do, or would a large USB Stick be good enough?
  • martin035
    • Apr 2014
    • 1308
    1. There is a 7 day (ish) xmltv EPG which the box downloads the data for, however, it can be problematic, read the various thread in this sub forum to see why.
    2. You can format the drive to NTFS as that will work, the size of drive depends on whether you want to keep the recordings, if you watch and delete then a much small drive would do ie 64gb stick drive.
    • DOUGALMCD
      • May 2011
      • 3229
      You would need to look at dual tuner box also if you want to record and watch at the same time.
      • lewdsnarler
        • Aug 2016
        • 6
        Thanks for letting me know... I'm not a big recorder, just wanted the option there. I've got a spare drive lying around, will try NTFS
        • Hadron
          • 2102
          The drive should work formatted to FAT32 or NTFS. The 4GB file limit won't be a problem with FAT32 as the recordings are recorded as a series of 1GB files, then played back in sequence when you watch the recording.
