This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5
Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe
As Many members know, I updated to a H series Zgemma a while back, but DK member 'madness85' has an original Zgemma S and has developed his image for use by others on the forum, this image will work on a Zgemma S or 2S
Openatv5.3 Backup Image with New improved SkyQ Skin, OTA update safe
* AutoBuoquetsMaker autoupdate daily
hi all had openbox for a long time wont Zgemma box but are they easy to set up like openbox ?
Flash your box with one of martin035's backup images & all the hard work will be done for you (except for the part we cannot discuss).
You will then have a box which will auto update the EPG & bouquets, gives the correct time all year round, has a record function that always works, has a nice clean Sky skin, can be configured to your liking, etc. etc.
No more having to download XMLTV EPG. No more having to constantly download channel lists every time a channel moves. No more having a clock that is only correct during the winter. No more...well you get the idea!
