f5s not working plzz help
  • oweny
    • 71
    hi I'm trying to upgrade my box as it just came up with no signal on every channel I have another box and all is fine I cant seem to fing the skyuk 28 transponder and don't know how to add or what the details off it would be
  • chris31560
    • Feb 2010
    • 912
    wow m8 one post will do...
    (1/125) 10847 V 23000.
    A LITTLE THANX GOES A LONG WAY
    • oweny
      • 71
      hi m8 iv lost the sky uk transponder how do I get it back on ive updated the software but the sky uk isn't there how do I add them sry bro for the posts
      • martin035
        • Apr 2014
        • 1308
        You need to install a channel list, get cwaites list from here and unzip and put on usb, then install on to your f5s
        The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
        • oweny
          • 71
          already done all that m8 I'm missin the sky uk 28 transponder and I don't know how to add it or get it
          • cunny
            • 4915
            Have you checked cables?
            • chris31560
              • Feb 2010
              • 912
              have you tryed a channel re,scan? if so check your cables and defo check the lnb on the dish................c
              • Hadron
                • 2102
                I haven't used cwaites list for a while, but installing it should also install a long list of satellites (including 28.2e).
                If you install cwaites channel list, and you still get no signal on all channels, then I suspect that doing your own scan on 28.2e will not pick up anything anyway.
                  Have you connected box to the secound tuner, on f5 people make connection to the loop.
                  • oweny
                    • 71
                    yeh m8 done everything my other box is fine it wont scan because it has no sky uk or w/e it was in the tp list its gone all cables are in correct way
                    • oweny
                      • 71
                      signal intenaty 36% signal quality is 10% but my other box is perfect in same feed
                      • oweny
                        • 71
                        added that m8 nothing is working
                        • oweny
                          • 71
                          yes bro all good on other boxes
                          • cunny
                            • 4915
                            So, if a box, using exact same feeds is ok? if so and have you checked the original box on another feed?
                            Just to be sure, try another cahnnel list, but I smell shot tuner
                            • oweny
                              • 71
                              what do u mean bro
