Similar Channel List to AJ's?
  • sickswan
    • May 2013
    • 43
    Just wondered if there are any channel lists that are updated regularly with a similar listing layout to AJ's. Has anyone used the Norfolk SR free channel list, is it any good? Cheers.
  • dunno87
    • Apr 2016
    • 84
    Why did not you just update it over the network and pick the Irish channel list. I used to get aj's but last time I checked a couple weeks ago he hadn't updated it since April.
    I say the Irish one is because it's same as uk one but u.k one I has loads of blank gaps between channels, the Irish doesn't and is layer out the same.
    • joe516
      • 1000
      The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
