Scrambled when connected to sky , connect to phone hotspot ... works (openbox v8)
  • xtravious
    • Sep 2016
    • 4
    hey guys ,
    when i connect my openbox V8 to a phone hotspot it loads all channels fine , when i disconnect and connect to my sky internet all channels (except freeview) says scrambled
    any suggestions?
  • cunny
    • 4915
    Originally posted by xtravious
    hey guys ,
    any suggestions?
    Are other devices working when connected to the router? also try using a ethernet cable
    Regards
    Sherlock
    • xtravious
      • Sep 2016
      • 4
      yeah got phone and PC connected wirelessly , tried connection through ethernet same problem im affraid :/ , also took it to a friends house who uses BT and it works fine just Sky internet is having none of it
      • cunny
        • 4915
        Is DCHP turned on in network settings?
        Or can you do a form of network test
        • xtravious
          • Sep 2016
          • 4
          DCHP is on , and just done a network test and all speeds are high enough :/ so confused , the signal % is 99 on the openbox too
          • cunny
            • 4915
            if bbc clears ok therre not a signal issue, there is a network issue. A network test should only test paramaters not speeds.
            are you using a Wifi adapter? If so run an ethernet cable
            • xtravious
              • Sep 2016
              • 4
              ran it through ethernet still no luck :/ and yeah wifi adapter but it picks up phone hot spot so it's not that
              • P&D
                • 2686
                Could be the firewall setting on the route....go into the networks settings on the box see if you have an IP address ?
                • joe516
                  • 1000
                  r u back on? m8
