V8S Golden Combo Tuner Box TP_Prog List
  • Ballindud
    Hi - anyone got any information as to how to setup channels on the above box - Thanks
  • martin035
    • Apr 2014
    • 1308
    To setup the Satellite side;
    If you have a user_db.bin (ie a TP_Prog List) then;
    ------------------------To load the Channel List------------------------Ensure user_db.bin on USB drive and plugged into box
    On your Openbox press Menu
    Press Left once
    Go down to USB Upgrade and press OK
    Press right once so that Upgrade Mode reads User DB
    You should see the Upgrade File listed as user_db_V8Combo.bin if not go down to the second line and move right until you do.
    Go down to "Start" and press OK
    At the prompt "Are you sure to burn flash?"  Answer yes
    After loading the box will reboot
    Finding a upto date user_db.bin is the hard part, good luck with that.
    • martin035
      • Apr 2014
      • 1308
      To setup the cable side;
