ADDING ANOTHER BOX..DIFFERENT ROOM
  • paulwill
    • Dec 2012
    • 5
    ive added another box, in bedroom, running through wifi dongle....box keeps freezing
    and box downstairs goes off when box in bedroom is switched on at same time
    any help please
  • DOUGALMCD
    • May 2011
    • 3229
    Wifi dongle may be rubbish so try powerline extenders they are better.
    Box downstairs going off as turning off or losing channels?
    What type of lnb are you using single/dual/or quad and are you trying to split cable?
    • paulwill
      • Dec 2012
      • 5
      single cable....usb wifi dongle.....box downstairs freezes, when box upstairs is on....box downstairs is on ethernet cable straight from router
      they are both v8s openboxs.......
      • paulwill
        • Dec 2012
        • 5
        think ive sorted it.....1 box needs 2 cables in...1 with loop line in
        thanks for your help
        cheers
        • Hadron
          • 2102
          Originally posted by paulwill
          single cable...
          You can't run 2 boxes from a single satellite feed. Each box needs it's own feed from the LNB.
          If you use the loop connector to feed another box they will interfere with eachother as each box sends 4 control signals to the LNB (hor/vert/hi/lo).
