Best OpenBox/SkyBox on the Market?
  • Gifted1ne
    • Sep 2016
    Ladies and gentlemen,
    HELLO!!
    previously, i had a Libertview F5s it had loads of problems with the Vertical channels as they always appeared as "no signal", i tried the "no signal fix" changed cables. Nothing ever resolved the problem, what i want to know is there a box out there, that will save me time from faffing around with the frequencies and loading channel lists etc.
    Basically i want a box that does not have the problem picking up the vertically polarized channels.
    Thank you for your help in advance.
  • Nobby Nutz
    • Apr 2012
    • 191
    You would be better looking at Enigma 2 (E2) boxes dependent on budget plenty on the market
    • Hadron
      • 2102
      Are you sure it was the F5s that was at fault & not the LNB?
      Do you get the vertical channels OK on another satellite box using that LNB?
      The zgemma H.2S is a great little twin tuner box that can be set up to load the channel list & EPG automatically overnight using martin035's backup image.
      • Gifted1ne
        • Sep 2016
        Thank you Nobby Nuts and Hadron.
        hadron, yes i changed cable made sure wall socket was not wobbly or anything?
        my dish was a communal dish that may have been the problem?
        But my sky+ box worked fine with vertical channels, when i plugged into to check availblity of channels.
