V8S DONE WRONG UPDATE HELP
  • portvalefanjosh
    • Dec 2013
    • 101
    Juts updated firmwere online as you do found some new one for a change and its the wrong one its for a v8 PLUS box what ever that is now the channel list is all over the screen. And its all gone too pot. How do i get it back to how it was ? ive tried upateding through network again but theres no firmwhere there at all. And every time i try to put the old firmware on using a usb it says odmi missmatch someone please help for the mrs gets bk thanks josh. Also it permently displays No Auth on the screen no matter what i do. It also says this every time i restart it fail; not config/mnt,uda 1/product_config.ini in usb disk
  • maff
    • May 2010
    • 15
    Give this a go. You should be able to load the correct Firmware using this method
    A how to guide on how to fix a corrupt firmware image in OpenBox S9/S10/S11/S12 and Skybox S10 F3 F4 F5 F5S A3 etc. Even if it seems bricked. Box does not respond or displays On or rebooting constantly ? If your box does not respond, or no displays light there is a good chance the current firmware on the box is somehow
    • portvalefanjosh
      • Dec 2013
      • 101
      Tried that thanks didn't work. I needed new box anyway , so bought openbox v9s instead. But the epg is pants.
      • joeyv6
        • Feb 2012
        • 6
        I've recently done this and had to reflash the box to get it working again. If you still have it then worth spending a couple of ?? on a USB to Serial Null Modem Cable and reflashing then put it for sale
        • blocks
          • Mar 2017
          My pc has not a rd232 connection
          • blocks
            • Mar 2017
            Sorry I meant no rs 232 port on any of my pc's
            • martyns
              • Apr 2017
              You can buy an rs232 to usb adapter (ebay sell them cheap) and off you go.
