anonymous information maybe the end maybe not?
  • Bennett21
    • Apr 2017
    • 18
    #46
    Is this is the end of the Openbox as we know it? Heart broken.
    • Mehar10
      • Apr 2017
      #47
      Originally posted by chuckles53
      Are they still no further forward with a fix.
      Hi Everybody,
      Read a lot of these posts and can confirm the following:
      This chaps new list fixes the SlySports2 issue
      http://www.openbox4u.co.uk/
      In terms of iptv, Titan-iptv works on openbox, I know because I use it. It is a bit annoying, as it can freeze and therefore you need to unplug the connection and reload, and start over, and this can happen when you simply change channel.
      Also it is delayed in comparison to what you normally get on the openbox feed.
      If you have downloaded a IPTV list and can see the channels but nothing loads, i would think it's because you are not paying the annual subscription, and suggest you try the 24 test option with Titan-iptv.
      In terms of the positives, if you know which channel you want to watch, and go to that channel, and don't change it, it works pretty good.
      Hope this helps.
      • Mehar10
        • Apr 2017
        #48
        Originally posted by Mee?kat
        Not trying to rubbish anything you have heard mate but a new config will not sort this,well i dont think so anyway, i thought it was a transponder issue but lincsat quickly showed me that it wasn't that,,, so it shows how much i know z...if it was a config edit i think we might have seen it by now
        Also there is many other providers sharing right now so your right,,it aint the end of cardsharing whether sly goes or not
        Hi Everybody,
        Hope this helps.
        • jubz
          • May 2010
          • 116
          #49
          Ok so how did he fix the ss2 issue? Can he not fix ss box office and the rest which are not clearing
          • martin035
            • Apr 2014
            • 1308
            #50
            There's no fix, all that's happened is people/bouquet plugins have swapped the non work SS2 UK for SS2 ROI on a different transponder
            • Treacle669
              • Apr 2017
              • 5
              #51
              Hey, Any updates on this issue please ?
              • joe516
                • 1000
                #52
                no fix...........
                information given is to be used for educational purposes only
                Don't Forget To Say Thanks If You Like My Post
                IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
                If It Ain't Broke Don't Fix It
                • bys561999
                  • Aug 2013
                  #53
                  Thanks for the information..
