zgemma help.
  • chris31560
    • Feb 2010
    • 912
    zgemma help.
    hi guys, just bought a zegemme h2s and all the channels are all over the place no order wot so ever, so was just wondering how to get the channels in order, this wont be the last post on this subject as iam only used to openbox , so any help would be useful.
    cheers.....................c
    A LITTLE THANX GOES A LONG WAY
  • digicon
    • 8261
    what type of channels are we talking about Sat/cable/IPTV
    • chris31560
      • Feb 2010
      • 912
      hi m8, just the free view sat......................c
      • digicon
        • 8261
        Dependant on Image use the ABM feature (Autobouquet maker) this will arrange all channels into order and in folders (FAVS)
        • chris31560
          • Feb 2010
          • 912
          hi, thanx for reply, how do i find out on what Image iam using? also where do I find ABM? bear with I'am new to this box ..................c
          • Hadron
            • Nov 2012
            • 2102
            I would recommend flashing your box with martin035's image. It's already set up with ABM etc. & lots of instructions are provided.
            This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
            It uses the OpenATV image.
            The current image should be shown on boot up when you switch the box on from cold using the power switch on the back. Or you could try Menu > info panel > infos > image-version. Or menu > information > about.
            • WD40
              • Nov 2015
              • 43
              Yes martin035's image is great and always channels start from bbc.
