hi guys, does anyone know how to swap the channels round on a zeggema h2s, its just that all my fta's are ok apart from itv it shows utv (ERROR TUNE FAILED), any help would be great.
chhers.....................c
Are you using the ABM to configure your Bouquets if so have you tried updating as ABM gets a regular update every few days, If not you can manually sort via the remote control
hi digicon, when I go to use ABM it scans for about 30 sec and then says AUTOBOUQETSMAKER timeout for tuner lock, and nothing changes, do you know wot is wrong.
i take it you have you Twin satellite version , if so check the connections on the back as the Tuner lock timeout means its not receiving a satellite signal
