Looking for a Image with a working Satfinder
  • unadkat
    • 340
    hi
    Am pretty much a Newbie when it comes to the sat scene
    Anyways 2 months back i got a 1m diseqc dish insalled
    and I have 2 linux boxes
    Currently I have the itgate 220 on cable tuner with V media of course
    And an Open media 500CS connected to V media and the 1M motorised Dish
    the guy who installed the Dish basically tuned the channels in for me as I couldn be able to do it
    what was happening is that I was select lets 19.2 e however on that I could only manage to find 400 channels and this was same wit all the satelites
    so I had to call him over again to Tune it in for me
    when he does it... it located all the channels with any problems at all... he was using some next level sat finder which he connected to my box so that he knows where the dish is moving
    Now I am running the Enigma image on the 500cs and the image does have a sat find built in but it doesnt seem to work
    So is there an image which has a working Sat finder?
    regards
    unadkat
  • kevin64
    • 170
    to find some sat you nead strong transponds other wise the motor woil just driver past them once you found them you nead to store them and then run a scan go to lying sat LyngSat - Lyngemark Satellite and find a FTA transponder on the sat you are looking for then make sure your reciver looks for that sat with that tansponder you should find your sats then
    • unadkat
      • 340
      thanks kevin I will give it a try and see how I do
      regards
      Unadkat
      • unadkat
        • 340
        Would it be easier to do it via Usals?
        regards
        unadkat
        • Sicilian
          • 168
          regards
          unadkat
          I'd say yes, if you look round you'll find loads of engima 1 motorised settings that you can send to your openmedia using dreamboxedit.
          D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
