Openbox S9 HD PVR Linux Satellite Box
  • tony34567
    • 102
    #76
    munna_07,
    try to reboot your router by taking out the electric pin then put it back again . hopefully it will sort the problem.
    • munna_07
      • 12
      #77
      Originally posted by tony34567
      munna_07,
      i tried this at first but made no difference.
      • manxspud
        • 1768
        #78
        I,m not a expert on these boxes, however have you a cline to put in the box. Its not a case of set it up and hey presto you open all the channels.
        @manx
        • hooley
          • 470
          #79
          Originally posted by munna_07
          hi guys. i could do with somw help here. all the channels are coming up with the 'scrambled' message. the free channels are ok. at first it used to happen a few times a day, gradually got worse and now not a single channel. my first thought is the server and the subscription. dish seems ok - perfect picture on free channels and internet connection is working fine - typing this message. any help would be appreciated, thanks in advance
          Sounds like a server problem if your fta channels are working. Get on to your provider
          • jocaspi
            • Oct 2010
            #80
            What version of Linux uses the Skybox?
            As I can connect to the PC?
            You can load software. Nfi Dreambox replacing. Abs?
            • munna_07
              • 12
              #81
              i have 4 clines which have been setup. iv been watching it for a few weeks now but recently the problem have occured
              • viganothing
                Skybox/openbox , does not run on Linux
                • manxspud
                  • 1768
                  #83
                  It runs on a closed linux not open linux.
                  @manx
                  • sob1467
                    • Feb 2010
                    • 604
                    #84
                    @manx
                    I am not trying to this thread of topic but can you briefly describe whats the difference between open linux and closed linux.
                    • manxspud
                      • 1768
                      #85
                      Open source software is software whose source code is published and made available to the public, enabling anyone to copy, modify and redistribute the source code without paying royalties or fees. Open source code evolves through community cooperation. These communities are composed of individual programmers as well as very large companies
                      Closed is the opposite .... source code not available ect ect
                      the os for these boxes is basic, does not give the owner much chance to play around. No telnet or ftp , cheap and cheerful hd boxes. Am tempted to get 1 myself.
                      @manx
                      • munna_07
                        • 12
                        #86
                        excellent explanation mate, thank you
                        • borderfox
                          • Apr 2010
                          • 39
                          #87
                          sourcing Openbox in HK?
                          Hi folks. I heard mention of $85/box from China/HK earlier in this thread. Does anyone have a link of a reputable supplier (as i know quality varies depending on who you order off)?
                          Not sure what the forum rules are (i know, i should check them!) but if its not permissible to post links, maybe someone could pm me the details?
                          Thanks & Regards,
                          borderfox
                          • dagenham67
                            • Mar 2009
                            • 32
                            #88
                            I managed to sort problem of successfully entering c line. The file was saved as text file rather than Cccamm.cfg file.Once changed to this box read file ok
                            • Martyo
                              hi could you point me in the direction of a tut
                              hi could you point me in the direction of a tut for an openbox.........marty
                              • hooley
                                • 470
                                #90
                                What do you need to know?
