Openbox S9 HD PVR Linux Satellite Box
EPG guilde
Just a note: the Openbox S9 HD spec reeds ......10) Support PVR(store in USB disk);
11) Multimedia files playback(by USB);
12) Support Electronic Program Guide(EPG) for 7 days;
13) Teletext and subtitle out through OSD;
so the openbox S9HD is supposed to support a 7 day EPG
usb problem
hi friends i am still having problem with uploading the lines via usb.i am doing all the things you say but nothing.i changed firm i changed usb stick but nothing .its says file not found.any one has any idea whats the problem.?? thanksComment
You will get a 7 day epg with some providers like sly de. It's up to each provider wether you get the 7 day. Some Linux boxes like dreambox, tm Linux and vu duo use plugins to provide the 7 day epg. The openbox dosent have any plugins like this.Just a note: the Openbox S9 HD spec reeds ......10) Support PVR(store in USB disk);
I have just got mine today and set it up without a problem.This might help.Copy your ccamconfg file to desktop format usb stick to FAT32.Put your cam file into usb stick and plug it into the box.Upgrade via usb and press green button to activate.Make sure there is a tick next to your c:line.Save and reboot and it should do the trick.Comment
I recived my Openbox S9 today, nice tuner
but network card was totaly dead! not even light in ethernet input
what to expect for 116$ with shipping
Edit:
anybody had ethernet problems? i tried 4 diffrent switches...
i now DB 7020 did not work on all switchesLast edited by kongarne; 23 November, 2010, 22:22.Comment
my friend what do you mean with desktop format usb stick all the sticks arent the same??what model stick do you have??.thank youI have just got mine today and set it up without a problem.This might help.Copy your ccamconfg file to desktop format usb stick to FAT32.Put your cam file into usb stick and plug it into the box.Upgrade via usb and press green button to activate.Make sure there is a tick next to your c:line.Save and reboot and it should do the trick.Comment
cfg file
friends another question how excact do we create an cfg file??and how do we name it to make openbox recognize it thank youComment
thanks my friend i know how to put the lines into the box but how we exact create a cfg file .with wordpad or notepad/?thanksComment
