0penboxs9 hd
  • lannyb2000
    • 38
    0penboxs9 hd
    hi
    just wondering if any 1 has any advice,the picture keeps freezing a lot especialy on the hd channels,is their any settings you can change to make it any better or any other image you could flash on to it like the d box,the bloke i got it off says it might be the sat dish thats up its 1 of the old big ones that had been left up,he had to change the lnb on it when he set it up.Any help would be appriciated as its my dads box
  • romunation
    • 12
    Sounds like it might be your cs server rather than the box itself mate. See if anyone else on your server is having the same issues.
    Also if you go into the big openbox page thread to page 26 I've posted the latest firmware but remember and backup your cccam info if that's what your using!
    • lannyb2000
      • 38
      openboxs9 hd
      cheers mate
      been on to the fella and he has switched servers but it is still freezing mainly on hd channels,am useing ccam could you change cams ie newcamed would this make it any better or is their any tutorials on how to save ccam and install new firmware would i have to tell the fella i am dealing with or like i say could i try and put a new image on the box,also other people on this server are useing dreambox no hd and they only get a freeze now and again
      • footyaddict
        • 86
        I'd just try a completely new share if i was you, most of them offer 24 hour trials. I tried quite a few before i found one that didn't glitch. Also make sure there are no torrents uploading as this can also cause glitching.
        • lannyb2000
          • 38
          cheers mate
          if i try a new share do we have to update the box to their firmware or will it work with whats on the box
          • hooley
            • 470
            The firmware you have on it should be grand, no need to change it if your changing your share. Are the free HD channels like itv and BBC freezing?
            • footyaddict
              • 86
              It will work with whatever is on there already, you'll just need to update your CCcam.cfg file.
              • lannyb2000
                • 38
                thanks every1 for the advice
                it freezes slightly on the free hd channels,just been watching city on my dreambox500 it broke up now and again but not as bad as me dads,so realy if you can not change any settings to make it any better its all down to the server you use,dose any 1 no if their any servers were this dose not happen or basicaly this happens on every server also some of my mates use a star....7 and they get all sly free without paying a sub is this possible any info please
                once again thanks for the advice every1
                • taree
                  • 11
                  After nov firmware no problem with rebooting and hd freezing.all hd chanells on hotbird working smoothly.problem must be ur server.
                  • Timmaa
                    • 88
                    Any problems on the FTA HD channels then that has nothing to do with your server. You need to look at your own set-up... Check your dish alignment, your LNB and your cabling.
                    • lannyb2000
                      • 38
                      SKY 3D
                      HI EVERY 1 DO THESE OPENBOX DO SKY 3D,I HAVE JUST BOUGHT A 3D TV AND 3D BLUE RAY PLAYS GREAT BUT WHEN I CONNECT IT TO MY OPENBOX IT DOSE NOT WORK YOU HAVE AN OPTION ON THE TV REMOTE TO CHANGE THE PICTURE AS SKY BROADCAST THE IMAGE SIDE BY SIDE YOU NEED TO CHANGE IT TO THIS ON YOUR TV REMOTE BUT WHEN I TRY IT IS JUST GREYED OUT SO YOU CAN NOT CHANGE IT,DO YOU HAVE TO UPGRADE THE SOFTWARE OR DOSE IT ONLY WORK ON SKY OFFICAL BOXS ANY ADVICE AS USUAL GREATLY APPRICIATED
                      CHEERS
                      VINCE
                      • pippoborg
                        • Apr 2011
                        sky 3D
                        I have an openbox 3D works fine I press ok on side by side all works well check your hdmi cable
                        • maravilloso1955
                          • Apr 2011
                          Hello everyone! my name is Joe, I just purchased an Openbox S9 and I cannot figure out what I need to make it work! after doing a blind scan! all I get is no signal on my screen (Help) Thanks.
                          • Manic01
                            • 5117
                            Start your own thread for help.
                            • tubs
                              • 420
                              most likely your dish may need a slight adjustment i had the same all channels wrer fine but hd not to good moved dish then perfect
