Latest channel list>>THANKS TO LAURELS53
  • mept1
    • 346
    L53 Openbox S9 Multi-Satellite Channel List v3.10 - [21 January 2011]
    L53 Openbox S9 Multi-Satellite Channel List v3.10 [21 January 2011]
    This channel list is best used with either the latest official Firmware, or with the latest L53_MOD_Dump file.
    This is a multi-satellite channel list covering satellites from 30west to 45east.
    It can also be used as a single satellite channel list, just click on the Zoom or SatList button and select the satellite you wish access from the satellite list.
    Default Settings:
    Channel list format: .dbs
    Default Motor Setting: DisEqC 1.2.
    Default LNB Setting: Universal [9750 - 10600]
    TV Channels: 4399
    Radio Channels: 0
    Favorite Channels: 0
    If used in an external channel editor, change extension from .dbs to .abs
    once you have edited the channel list, change the extension back to .dbs
    What's New:
    Channel list type [TP_PROG]
    A number of new or updated channels added on various satellites.
    To avoid any possable conflicts, it is always wise to delete the channels from your receiver before installing.
    To remove all channels click Menu -> Edit Channel -> Delete All
    To install this channel list, simply transfer the unzipped channel list to a USB Stick, and then insert the USB Stick into the USB port, which is located on the rear of the receiver, then follow the instructions below.
    Click Menu -> Tools -> Upgrade By USB, then in 'Upgrade Mode' select 'Misc Files'
    then click on 'Select & Upgrade' and select OPTION 1 [TP_PROG] now click the OK button,
    when you see a check mark or tick next to the TP_PROG, click the yellow button to install.
    Once the file have been installed, reboot the receiver, once rebooted you can then click the Zoom or SatList button, and directly select any satellite from within the satellite data base list.
    Anyone may use, or share this modified Dump file, all I ask is that you do not remove, or edit the files included in any way, or add any other extra files, which are mainly spam, giving credit to some obscure web site.
    Of course we are aware of the fact, that some still have a tendancy to ignore the above request.
    All the best
    Laurals
  • smok3y666
    • Sep 2009
    • 18
    Thanks for this.
    • Adam_UK
      • 464
      Can this channel list be loaded on non motorized system? my system is 4 fixed lnbs and I use DisEqC 1.1 to set it up.
      • patelar
        • 8
        Adding few extra sky channels and how?
        Hi all
        This is working brilliantly but I could do with adding only few extra channels e.g Islam and Peace TV.
        I only know how to do a full scan but is it possible to individually add one or two extra channels and how?
        Thanks for any help/advice
        • mept1
          • 346
          Press menu>>tvchannel list>>scroll across to eurobird 1 &Ast>> press the fav button on remote>>look for your desired chanel IE(peace channel)>>>highlite it>>add to which fav list you desire.
          good luck
          • patelar
            • 8
            Hi
            I done the above and can't find extra channels as there is only a total of 358 channels stored by Laurels53 zipfile
            Usually SKY have nearly have 900 channels so what I need is how to search manually for that one extra channel to be added on to the 358 total.
            I know that on Lyngsat.com I can look up the individual Freq.
            Tp eg Peace TV is
            12560 H
            tp F1U
            DVB-S
            SR 27500
            FEC 2/3
            • mept1
              • 346
              Thats way low,.for channels sly uk,....On my openbox theres 800,...try my channels list below.
              • patelar
                • 8
                Hi
                Does the 800 channels cause any rebooting issues when selectiing any channels and like Laureels53 does it cover other satellites channels for a motorised dish?
                • mept1
                  • 346
                  no rebooting,....i,v removed all other sats in that channel list except 28.2 as i thought you only wanted that,..if you need full moterised list,.let me no.............
                  good luck
                  • casey95
                    problem with dm900-c11
                    I cant see any other channels. Need input pin how?????? pm me pls thanks
                    • patelar
                      • 8
                      Hi mept1
                      Can you do the 800 sky 28 deg list channel list with the other motorised dish list
                      • smok3y666
                        • Sep 2009
                        • 18
                        Anyone got the new 3.20?
                        • patthewan
                          Default Settings:
                          TV Channels: 4399
                          Radio Channels: 0
                          What's New:
                          All the best
                          Laurals
                          hey thanks this is a realy big help to me been at this all day just shows reading and searching pays off
                          • kingtj64
                            • Dec 2010
                            • 32
                            Hi mept1,
                            thanks for all your work.
                            which firmware is best with this ?
                            Cheers
                            • mept1
                              • 346
                              As it,s a dump it dont matter.
