Open box hell!!
  • choozay
    • 23
    Open box hell!!
    Can sum one plzzz help me with my open box!! Im ready to smah it into bits!!
    I for sum reason cant get my Clines to show online!! I have been trying to fix this damn box for 5 days!!!!
    If no one can help, does anyone have the orginal firmware?? will sell this blasted box!!
  • mept1
    • 346
    Calm dowm!!!
    explain what your doing.
    • rapscallion
      • 141
      Format usb drive to fat32
      Using notepad put what you want onto notepad
      Save as
      File name CCcam.cfg
      Change the box below to all files instead of text document and save.
      Put drive into open box and take it from there
      • choozay
        • 23
        Im adding the Lines via a usb. I have managed to get the line uploaded. I have DHCP on and i have opened ports and created DYNDNS.
        After i do a reboot the line shows as offline!! I dnt get what im doing anything wrong?
        Plz help
        • choozay
          • 23
          My friend has given a cline to connect to his server by the way..I dont if there is an issue with dat??
          • mept1
            • 346
            yep,...it could be dead.
            • choozay
              • 23
              any idea where i could get access to one?? i would only need it for 5 mins...do u think any one would allow me access??
              • zag2me
                you need to active the cline in the config. Its the green button I think. Then reboot.
                • bighun
                  • Nov 2010
                  • 151
                  make sure and press the exit button on the remote when you have put in your cline and make sure there is a tick on your cline then reboot the box and that should do it
                  • bigup
                    • 69
                    choozay, did you get this sorted?
                    • opsmonkey
                      • 5379
                      FFS guys.. read the rules.. No cardsharing CLine chat
                      • promo7uk
                        • 4
                        HERE YOU GOT LATEST FIRMWARE WITH LATEST CCcam new update also uk sly channel list ,,
                        once you add cccam addline . make shure you press green button on remote to get it to work,
                        then once you have save it press menu so you goto screen sayin encrypted. then goto network add box via dhcp auto on,
                        now press apply at bottom.
                        now goto menu once saved,, then put box in standby mode.!
                        wait 10 seconds if u have done everything right there ya go,,, box is now working and decrypting,this works just this second used it myself.
