Box says copy on front display
  • TheCoder
    • Jun 2011
    • 693
    #31
    Originally posted by the man
    that is very cold from the seller , where u get it from buddy? link?
    and when?
    theres laws to protected buyers
    The laws seem to be very vague once you've modified absolutely anything from the original configuration. Simply 'flashing' a box, even with manufacturer approved firmware, can easily invalidate any warranty as your deemed to of tampered with the product by performing an unauthourised modification. As far as the law seems to be concerned, flashing firmware is something that should only be carried out by manufacturer approved personnel.
    PC Motherboards seem especially prone to this problem with most 'flash updater' programs coming with a disclaimer that if it all goes wrong then the manufactuer takes no liability whatsoever for any damage you've caused to the board.
    • taree
      • 11
      #32
      I m facing strange problem.after all this process download was finished successfull.but when i disconect the main power and put it again.now openbox is in standby mod.only red light is on.what should i do?any chance of power supply failure?
      • nictalope
        • Jul 2012
        I have the same problem that Dub12Dave, i will try the same and post again
        • vinchuk
          • Sep 2012
          SuperBox S9000HD same error
          I'm experiencing same problem. Could you tell me I have to use some JTAG interface or is it only necessary RS232 to solve this.
          Please help
