DreamElite Questions.
  • reloaded
    • Apr 2009
    • 225
    Guys
    I have 2 very simple questions...
    1. How do i install a CAM manually on the dreamelite image?
    and finally,
    2. the best way to uninstall a CAM that you no longer want to use?
    many thanks.
    New Season...New hope! YNWA.
  • plasterer
    • 1631
    Just use an FTP program like ,Flash FXP
    you will find the cam in the var/bin folder .............Paul
    If your Happy with the Help push the Thanx button
    PAUL
    • reloaded
      • Apr 2009
      • 225
      so once iv downloaded the cam, do i ftp it across to the
      etc folder or temp?
      once that is done, does it need to be installed, or just transferring the config file is enough?
      thanks.
      • southpaw
        • 2233
        Just install tunisiasat plugin , get your cccam from there ,
        Sent from my Blade using Tapatalk
        • reloaded
          • Apr 2009
          • 225
          southpaw
          i did exactly that, and installed from blackhole option...
          was i supposed to get it from the dreamelite section?
          all i can see under etc, is cccam.cfg
          i'm i missing more files?
          if wanted to uninstall it, whats the best way of doing it?
          cheers.
          • reloaded
            • Apr 2009
            • 225
            when i try to access the cam, it reads this message.
            ''sorry, access to cccam is refused, please check to see if cccam is running, and your webinfo settings''
            anyone have any ideas what this means???
            • southpaw
              • 2233
              Have you turned cccam on mate ?
              • southpaw
                • 2233
                Also I am struggling to see what you trying to do mate , also why would you want to uninstall it ?
                • reloaded
                  • Apr 2009
                  • 225
                  southpaw
                  its definately turned on...
                  blue button (dreamelite) shows cccam 2.2.1 as the cam working.
                  then press the green button, and red for the cam status, u see the message below:
                  it was a straight download from tunisia sat, i downloadec both the config and softcam.
                  i'm baffed mate!
                  • NaNaNiii
                    • Dec 2010
                    • 167
                    Have you selected cccam 2.2.1 as the one to run? Press blue once then press right to toggle through the cams. Took me a while to realise this (Flashed box 3 times) ::
                    • reloaded
                      • Apr 2009
                      • 225
                      mate
                      already did this like a hundred times!
                      cccam is selected.
                      but when i press green and red, for status, the above message keeps coming up.
                      just dont get it.
                      • benny/9
                        • 1964
                        Originally posted by reloaded
                        mate
                        cccam is selected.
                        just dont get it.
                        is this any use mate
                        new server for Dream Elite 1.33
                        As we all know the Dream Elite server is "dead".
                        But now it's got a new server where you can download
                        the plugins directly via remote control.
                        All you have to do is to change where to download these plugins from.
                        Proceed as follows:
                        Make sure you have installed Dream Elite 1.33
                        FTP file "DE-softcam-feed.ipk" to the "tmp" on your Dreambox
                        Press the green button on the remote control
                        Press the yellow button on the remote control
                        Select "Manual Install IPK packges"
                        Choose to install "DE-softcam-feed.ipk"
                        Press Menu / Settings / System / Customize
                        Change the "Setup Type" to "Expert"
                        Press Menu / Setup / Software Management / Advanced Options /
                        Choose upgrade source
                        Select "softcams-feed" and click OK
                        Press the Exit
                        Choose "package management" and wait for "packet manager"
                        lists the entire list of downloadable plugins.
                        Then select what you want to download. Simple and easy
                        Please Read Carefully!
                        • reloaded
                          • Apr 2009
                          • 225
                          thanks mate..
                          but didnt work..
                          the cccam that i installed from the server may be dodgy?
                          • bubbles69
                            • Feb 2010
                            • 1156
                            Maybe yo didnt install cccam for de images look here for manual addons,
                            DreamElite Addons Download Here
                            • reloaded
                              • Apr 2009
                              • 225
                              bubbles,
                              the ccam 2.2.1 i downloaed from tunisia sat was buggered somwhere along the installation!
                              so i d/loaded a clean full version of 2.2.1
                              and its working like it shud be.
                              cheers for the nabilo addon link above.
                              thanks.
