Headache with motor
  • junger
    • 200
    Headache with motor
    I have spent a few hours lining up the desq 1.2 motor which now sweeps across all the satellites in order (well from thor to astra 2), i have entered all the sats in the tuner menu (advanced etc). I go down to satfinder and it locks onto the correct sat (ie Hotbird) when i select the the frequency etc: and return to the menu to go into sat positioner the motor goes back to the first storage position (28.2). even though I selected say hotbird. anyone help please
    If only I had more time that I could waste
  • bubbles69
    • Feb 2010
    • 1146
    What box you using on dm800 you use usals and enter long and lat
    • junger
      • 200
      DM800HD can I use usals methed on a desq1.2?
      • bubbles69
        • Feb 2010
        • 1146
        yes this is the only way i have setup a dm800 on motor think, there is a guide somewhere,
        think you set dish at 1w and enter long lat correctly for your house and thats it it knows where every sat is
        • junger
          • 200
          Ok bubbles
          I have set my tuner to usals on my long lat, i have done this on each sat, I then lined up thor .8 and bbc world cleared, whn i select (green ) satellite the motor does not move to the selected satellite but stops on thor Ahhhhhhhhh!
          • cris808
            • 133
            Yeah use USALS. I set mine at 0.8w as it has the strongest SNR on free to air channels like BBC World etc.
            Enter Longitude & Latitude and you should be up and running mate.
            • andy91
              • Aug 2010
              • 3583
              Menu/Setup/Service Searcing/Tuner Configuration/ Choose Simple positioner mode and put your Long and lat in,its the best way and use the latest set of bouquets from Sgtflipflop or Catseyes and you will be fine.
              Usals is the easiest just make sure your Long and Lat are correct.
              Andy.
              • cris808
                • 133
                Yeah make sure your Long & Lat are correct otherwise it will not work properly. Also for each satellite choose LNB1 on the advanced mode.
                • junger
                  • 200
                  53?24'N entered as 053.350N, is that the correct format. Still the motor does not move away from thor, does it matter if it's a clone?
                  • junger
                    • 200
                    All Sorted
                    Thanks All
                    I have sorted the problem, it was a faulty 1.2.motor, new motor fitted and sats scanned, one thing though, even though i entered all the sats from thor to arabsat, some sats are missing, any help appreciated
                    Junger
                    • mario123
                      • 383
                      Originally posted by junger
                      Thanks All
                      Junger
                      for the weaker sats i just use fine tune it as it can be hard to pick them up with usauls unless lined up 100%
