hard drive
  • the rock
    • 217
    hard drive
    can not get hard drive to initialization on dreambox with dream eliite image any ideas any help would be great thanks guys also getting mkfs failed when i try
  • southpaw
    • 2233
    As you got no re-plies i will give you a couple of pointers ,as i aint no expert .
    is the hdd formatted , (ext3 format i think)
    is the hdd mounted (go to mount manager to check)
    failing that , for some reason various images have various results in hdd setup , may be worth trying another image , although i always believed DE was one of the easier for hdd setup
    Good luck , and maybe somebody more usefull might give ya a pointer now your bumped back to the top
    • the rock
      • 217
      ok got it sorted what i did was mount the drive to /media/hdd and then i let the machine format it the machine will have to restart after the mount and format and after try can you time shift i you can we are nearly there ftp the box and go to media and open hdd inside this folder there was a folder called movie open this and created a new folder /hdd/movie and save this worked for me hope it helps oh after i tried to record something and it worked did not initialization the hard drive left it alone
