dcc tutorial
  • patch
    • 69
    dcc tutorial
    is there a tutorial for dcc on this forum , im sure i once saw one , if not does anyone know of one . thanks
  • wilf
    • 1618
    when you connect for the first time you are met with a screen something like this
    once you have the correct ips and password in the boxes those red lines will go green only then can you proceed. if you dont know your ip then hit the search button next to each box once they are green like this
    go do what you need to do
    • patch
      • 69
      thanks is there no tutorial to explain how to use tenet and ftp . thanks
      • wilf
        • 1618
        not sure if there is on this site to be honest, i only use telnet to change password and if you hit the ftp button you can see all the folders in there, i go into the ones i want and edit what i need to. all the things i needed to change i found instruction for on you tube, give that a whirl
        • piopat
          • 708
          what do you want to ftp mate ? or do you want to edit a file .if you let us know what you are wanting to do we can advise better.
          i love it when a dreambox comes together.
          • southpaw
            • 2233
            I find a dedicated FTP program easier. I always use filezilla and its free
            • COVENANTS LAND
              • 15
              hello Wilf
              I've been trying to use this program for my SV combo+ but it always errors is it because it's for dreambox? this is what i was sent
              sorry if this is a stupid quesion
              the error is "10057 socket is not conneted" any help would be very welcome
              • piopat
                • 708
                that usually means the ip address (for the box) is wrong ,you need to get the ip address and compare it with the ip on the pc screen ,the ip looks like this 192.168.1.4 (the number at the end can be different ) so if your box ip is 192.168.1.3 and on the pc screen it say 192.168.1.4 you will need to change the 4 to 3 or what ever the last number of the box ip is .
                by the way dream control center is for a dreambox but it may work .
