DREAM BOX STOP WORKING WITH NEW VM HUB
  • simon187
    • Apr 2011
    • 11
    I GOT THE NEW VM HUB AND SINCE IT HAS BEEN INSTALLED THE DREAM BOX HAS STOPPED WORKIN ITS A STATIC IP.... CAN ANYONE HELP???
  • TcG1
    • 68
    Ports ??? have you opened the relevent port on the hub to allow access ?
    • lincsat
      • 1228
      Your external IP has likely changed, that could be a factor depending on your circumstances.
      • homer41
        • 207
        is it dhcp enabled
        • simon187
          • Apr 2011
          • 11
          im not to familiar with this can i plz get some guidance if dats ok? wat is the dchp
          • simon187
            • Apr 2011
            • 11
            and also hw do i open up the ports to allow access
            • mark8393
              • 2305
              i installed a new super hub a week ago, then my 500 stopped. all i did was a reboot of box, and all was fine.
              500 works and blade works. just ip changed
              • simon187
                • Apr 2011
                • 11
                when i tryed to reboot the box it just kept comin up with "fatal error" and dusnt work
                • simon187
                  • Apr 2011
                  • 11
                  and yes it picks it up on another ip address
                  • mark8393
                    • 2305
                    sounds like more than just your hub.
                    by reboot i mean
                    press menu
                    shutdown
                    then reboot now
                    this is on gemini 4.2 image
                    what are you actually doing?
                    • simon187
                      • Apr 2011
                      • 11
                      as soon as i click on reboot now a "fatal error" could not open servicefile and then reboots.
                      • mdt
                        • 3034
                        id start a fresh m8 and do a re-flash and then add the cams/configs and channel lists. i have had "fatal error" a couple of times but a re-flash with dream-up cures the problem. regards mdt
                        • simon187
                          • Apr 2011
                          • 11
                          can not acesse pin protected
                          • simon187
                            • Apr 2011
                            • 11
                            have u got a password for the dream box?
                            • Fergal
                              • 1007
                              Go into network/communication settings and make sure dhcp is ticked save then switch off at the mains then turn it back on.
