Menu
Setup
Sat Configuration
Select 2 sat setup
Select your two Sats
Exit (once)
Find Sat
Get it to scan for each sat and Lock on both
Exit (once)
Automatic Transponder Scan
Select one of your two Sats
Green
When scan ends and it asks "Do you want to scan another sat?
Select yes
Select your second sat
Green
When scan ends, select No
Exit, Exit to main screen
TV
Satellites
Select either of your two
Red
Select a channel and away you go
Setup
Sat Configuration
Select 2 sat setup
Exit (once)
Find Sat
Exit (once)
Green
Select yes
Green
TV
Satellites
Red
