Cannot get it to work.Trying to play AVI from my comp.Worked great with Dream Elite 1.Any help?
VLc With the new Dream elite 2
Tags: None
You will need the vlc player patch. You can install the latest Tspanel here http://www.digital-kaos.co.uk/forums...4/#post1104282 which will have it in addons - tools.
Or if you want the standalone ipk to manually install let me know.
I tried the image for two days but reverted back since so have not tried the vlc patch.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
DL from TS. It reads the drive but gives the green screen. If you give us the ipk file I'll give that a go.
PS Thanks for your helpComment
This is the latest version from mfaraj57 unzip it first and try it. As said I have not tried it on that image.Attached FilesI refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Sorry off topic but can you use an original image on a clone box if you patch it with the correct bootloader for your clone after the flash?Comment
