ocsam + cccam 2.1.3
  • mtv1
    The Stig PT
    • 4413
    #31
    ask and you will receive nice one m8
    • piopat
      • 708
      #32
      thanks mtv1 ,jojo wait untill the clock counts down to 0 seconds and then you will see regular download then click on that and download . with any luck it should work fine as its enigma1 and suitable for gemini ,if it installs you can easily upgrade to a newer version of oscam if you want to and then all you have to do is replace the default config files with the config files davvo gave you and i hope your problem will be solved .
      • Jo-Jo
        • 511
        #33
        ok that installed fine and working i can see in cccam info i am getting my 1 card through the n line but i am getting no active clients as if no one else can connect to me through it
        p.s when i try to access the oscam webif i get access denied
        • piopat
          • 708
          #34
          you will have to put in the oscam config files and the cccam config file that davvo gave you .
          • Jo-Jo
            • 511
            #35
            ok i have tried changing the port in oscam from 12000 to 12001 and editing this in the cccam cfg on the n line i then get active clients but oscam not reading the card arghhhh
            • Jo-Jo
              • 511
              #36
              i have the config files all in stuck fo ideas now i can start oscam and cccam and clear them locally on my server box but on my box upstairs it recieves nothing
              • Jo-Jo
                • 511
                #37
                ok i have managed tgo get webif working by changing its port to 8080 but still in cccam info pages i have no connected clients any suggestions ?
                • piopat
                  • 708
                  #38
                  if your using oscam and cccam with an n line cccam info will no longer be able to tell you about your clients ,you use oscam.info for that (or webinfo). all you need in cccam.cfg (in the box with the card in it ) is the n line disable or delete everything else .
                  we shouldnt really be talking about this stuff on the open forum so i sent you a pm which may help .
                  • Jo-Jo
                    • 511
                    #39
                    i thought the basis of using oscam with cccam was this
                    oscam reads the card and forwards it via the n line to cccam protocol thus cccam remaining to forward your card etc
                    • piopat
                      • 708
                      #40
                      yes cccam forwards the card (to use your words ) but thats about all oscam does everything else . so in that sense cccam is no longer reading your card or handling clients so there would be nothing in cccam info ,you get your client info from oscam webinfo or you can get an oscam.info plugin .
                      • lincsat
                        • 1228
                        #41
                        I believe that you can use CCcam (rather than OSCam) to re-share. N Lines can be re-shared around 7 hops. You may have your ports mixed up.
                        • satsmo
                          • 6397
                          #42
                          7 hops, (I know what you are relating it to), be we definitely aren't talking local here unless the lad has a mansion.
                          Please keep the posts within the boundaries of or rules as they are teetering on the edge of them going by the last few posts above.
                          Thanks.
                          BTW did we not have a thread exactly the same as this already with all the info required within??
                          • Jo-Jo
                            • 511
                            #43
                            i only want locally but cant even get that i know it should but isnt when you say ports messed up what do you mean i use 12000 for cccam and oscam do them both have to be on diffeent ports ?
                            • Jo-Jo
                              • 511
                              #44
                              yay great stuff i changed my port in oscam cfg to a different on as cccam and its all working great now thanks so much
                              • Jo-Jo
                                • 511
                                #45
                                i dont seem to be clearing MUTV though on my upstairs box but everything else is anyone know why this would be
