port forwarding
  • HORNET250
    • Jul 2010
    • 9
    port forwarding
    hi can anyone help im trying to get one dreambox to talk to a second box at a differnet location,dreambox 1 has my fline in it and dreambox 2 has my cline in it,dreambox 1 is connected to a netgear router and dreambox 2 is connected to a adsl sky router,i have logged into my netgear router and port forward 12000 and put dreambox1 ip address in when i do a test with open port check i get this message:
    TCP
    EXTERNAL IP ADDRESS SHOWS ###########
    PING RESULT WE WERE NOT ABLE TO PING YOUR ROUTER
    PORT CHECK RESULT THE PORT IS OPEN ON ANOTHER DEVICE
    when i check UDP i get this message
    PORT CHECK RESULT THE PORT IS NOT OPEN OR REACHABLE.
    i dont know what i am doing wrong here i just cant get the 2 boxes to communicate with each other do i need to forward port the router at the second location to port 12000 at the other location,also do i have to use dynds or can i just use my normal ip address? any help would be great
  • cgscott
    • 3513
    You need dyndns address and you need to tell cccam.cfg what port to go through. There is more to it than just opening ports. Receiving is easy no config except a line.
    We cant go into great depth here but you will find it all over the web. From a simple config to a more expert one.
    Patience is a virtue.
    • southpaw
      • 2233
      you say one box is connected to a sky router, please tell me its not on sky broadband
      • piopat
        • 708
        i agree with southpaw it really is not a good idea to cs using sly braodband ,ive sent you a pm with info regarding the cs side and opening a port but your mate might want to consider changing broadband supplier .
