DREAMBOX EDIT....DATEI NICHT GEFUNDEN
  • msmmr
    • Oct 2010
    • 28
    #16
    Originally posted by andy91
    Sounds like there aae obvious errors with his bouquets.
    For now i would use an older working version of his bouquets and cut and paste any none working channels or use someone elses till these are sorted out.
    EDIT- Let us know what your problem was it might help others on the forum.
    Andy.
    Hi, the bouquets i was using were made by myself from b16mcc's frontend softwarre where u can make ur own b16 style S** numberng bouquets, there was a prob in his database which created an error and this is why the porgram dreamboxedit was giving datei nicht gefunden.
    All sorted now. Cheers
    • Coach
      • May 2010
      • 16
      #17
      I too am getting this Datei Nicht Gefunden (file not found) error if I download anybody's bouquet it will upload fine to the box, if I add a simple blank bouqet or a populated one or even import one I get the error.
      I've tried many different versions of dbedit bit they are all the same.
      I am mainly working with Catseyes Enigma2 bouquet
      Box is DM800SE running Nemesis on Enigma2
      DBEdit ver is 4.1.0.1 IHAD edition
      NOTHING shows in the error log at all NOT A THING, the log stops on the last sucessful file which is usually bouquets.tv but nothing goes up to the DM other than the 1st couple of files.
      Also after this error it loses ftp connection to the DM and you have to restart dbedit.
