Where are the Keys with CCcam in Enigma2 and Gemini 3.0.9
  • viliev
    Where are the Keys with CCcam in Enigma2 and Gemini 3.0.9.
    Thank you.
  • thered
    • Aug 2008
    • 4915
    you put your own keys in m8
    • opsmonkey
      • 5379
      are you on about where you put downloaded keyfiles..?
      /var/keys
      and
      /var/scce
      • viliev
        /var/keys
        and
        /var/scce
        NO,NO,NO AND NO..... I COULD'T FOUND KYES IN MY ENIGMA2 SA GEMINI 3.0.9 I CCCAM. WHERE SHOUT I PUT IT????!!!!!
        • opsmonkey
          • 5379
          sorry mate i cant understand what you are trying to say..?
          are you trying to find where to put your keys..?
          You have key files..?
          Or actual keys..?
          Is this any help..?
          These are the files needed by CCcam:
          What Softcam.Key should CCcam try to read ?
          Defaults to /var/keys/SoftCam.Key
          What AutoRoll.Key should CCcam try to read ?
          Defaults to /var/keys/AutoRoll.Key
          What constant.cw should CCcam try to read
          Defaults to /var/keys/constant.cw
          To be honest just use this..:
          for dm800 rename script to latestkey_userscript.sh
          othervise it wont work, latestkey is just the name for it and _userscript.sh is that matters most.
          put it in usr/script with dcc and change attribute to 755
          thats it. then you can use blue button 2 times and go to script...there you go..
