Move from VM to Satellite
  • Reddog622
    • Jun 2009
    • 88
    Hi Guys
    Due to the Nag 3 wipe-out on VM I am looking at moving into the satellite world, the only problem is I have no idea what box I need get to receive all the ?best channels?.
    Ideally I would like a receiver box that plays HD and has the ability to record.
    Would a free view satellite dish be ok or would I need a sky dish?
    Please help any advice would be great.
    Regards
    Red
  • blueflash234
    • Mar 2009
    • 904
    to get the best out of it you would be better off getting at least a 80cm dish but if you are up north a 1 metre dish and put a motor on it to get the best possible choice there are so many boxs out there it will depend on how much you want to spend and if you want a plug and play or a linux box
    • Reddog622
      • Jun 2009
      • 88
      so could i get all the best channels with any box?
      • irsh12
        • Oct 2010
        • 108
        By best channels do you mean all the sky uk ones or other non uk providers aswell?
        • Reddog622
          • Jun 2009
          • 88
          By best channels I mean the channels that you would normally have to subscribe too but can get without subscribing.
          Cheers
          Red
          • blueflash234
            • Mar 2009
            • 904
            you wont get sky unless you c/s and even that may be difficult to do soon as well if you go that route take it month by month
            • darguewin
              • Feb 2010
              • 116
              this has nothing to do with the thread.
              but y will c/s be hard soon?
              • nathan2007
                • Jun 2011
                • 448
                mate dont worry it is just a new encryption but as we know from previous encryptions nothing is unfixable in time
                • milkcup86
                  • Feb 2011
                  • 62
                  Do you have a dish or ever had a dish on your house? If not time to get your drill out?
                  Sky dishes can work motorised or alternatively, if you can't afford a motorised set up, a multi-lnb set up is a good alternative with lots of choice of channels to watch.
                  I would always advised on a multi sat set up as the amount of providers out there we hope there will always be something to watch.
                  • darguewin
                    • Feb 2010
                    • 116
                    how dose the multi lnb work? my dm800 only has 1 reciver
                    • milkcup86
                      • Feb 2011
                      • 62
                      Yes you feed all the lnbs into a diseqc switch. I have mine gaffer taped to the back of my dish! The switch then has one coax that goes to the receiver.
                      You set the receiver to tell it what ports you have put the various lnbs on and hey presto loads more channels to watch. Instant changing as well unlike motorised satellites and you can run multiple boxes of the lnbs if you buy dual or quad lnbs!
                      You can get diseqc switches that can work with 16 lnbs.
                      a 4 way diseqc switch you can get for about ?3.50 off ebay
                      • darguewin
                        • Feb 2010
                        • 116
                        do you have to have a big dish to do this? as i have a standard sky dish pointing at 28.2
                        • milkcup86
                          • Feb 2011
                          • 62
                          You might be able to sandwich and lnb on the side for 19e. I was going to do some experiments with a set up like this and see what signal / quality levels I could get.
                          Depending if you happy changing the mount, you could motorise the little dish also but obviously more money.
