Unable to Connect Dreambox to PC
  • nazak47
    • Jun 2011
    • 13
    Ive bought a Null Modem Cable but am having trouble connecting to it from my PC. Keep getting the following error "Connection Prepared, now switch on the dreambox. I connect the null modem cable first then press connect and that message comes so i insert the power cable but no luck stays at that message.
    Can anyone help?
    The cable ive purchased is: Female Serial Null Modem Cable to Update Satellite Box on eBay (end time 03-Jul-11 23:30:44 BST)
  • Fergal
    • Aug 2008
    • 1007
    You don't say what box it is dm500 or dm800 and what are you trying to do? does the box boot up fully?
    • Dreamer
      • 2020
      Have you read the guide here Naz?
      The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
      • nazak47
        • Jun 2011
        • 13
        Using Dm500s its that little black box, and it does power on theres a green light on the front. Ive just got the box yday and the cable today trying to flash an image to it.
        And dreamer lemme have a quick go at the guide you posted
        also on my comp there are
        com1
        com2
        com3
        com10
        tried all of em still no luck
        • Fergal
          • Aug 2008
          • 1007
          But does the box boot up? can you get to the menu's on the screen? if you can check the ip addy it has been given and just flash it using a ethernet cable via your router
          Flashing Via Telnet
          To telnet, click START > RUN and type Telnet ip.address.of.dreambox
          A command window will appear, enter username root and password dreambox.
          This method will only work with a .img image file.
          * Rename the image file to backup.img
          * FTP the image file to the /tmp folder on the dreambox
          * Telnet to your box and paste the following command:
          cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
          once finished reboot the box
          Sorted
          • nazak47
            • Jun 2011
            • 13
            Ok sorry to sound abit stupid but what is telnet i tried entering "telnet 192.***.*.**" but gives me an error
            • steve67474
              • Mar 2010
              • 98
              flashing box
              are the ports on your pc genuine ones or usb to serial adapters? they are known to give issues. what level of dreamup are you using? do a search for this "Dreambox_500s_toolbox_by_Slipknot.rar" and use the dreamup in that and see how it goes. hope this helps
              Learn how to hold a bear with a mic in your hand Kylie LOL
