Livefootball version 2.0 enigma2 plugin
yes thanks for the suggestion
zap to channel available in soccer on satellite so i can imported to soccer direct feeds
thanksComment
copy the ipk file to tmp folder in dreambox
if you have TSpanel open tools-1 and file explorer and go to tmp folder and click the file
or if you have telnet program write this command after connecting with dreambox
opkg install /tmp/enigma2-plugin-extensions-livefootball_4.1_mipsel.ipk
restart gui and look in plugins for livefootballComment
I've got livefootball 4.1 plugin installed but when i goto the middle icon (soccer on satellites) I get error message "error processing data, please update liveonsat url from about & updates option and try again"
When I goto about and updates it says "no updates available"
I've uninstalled and reinstalled and still got same problem.Comment
TM800HD
Would this work on a TM800HD ?
I tried installing but got the following error
-sh opkg: not found
Its tef in /tmp/
Any ideas ?Comment
version 4.2 for eo2.0 and oe1.6 images
updates;
-fix soccer on satellite
-fix minor bugs
installation:
-from previous version-update for oe 1.6 images
-TSpanel servers-plugins
-by manaul methods
download
Livefootball-oe1.6_4.2_all
Livefootball-oe2.0_4.2_all
have fun
mfaraj57-2012Comment
i do not know about tm800 but if it is eni
gma2 then the plugin should work
opkg is not found,this is problem in opkg system try to see how the packages installed for this model,try to use ipkg install /tmp/plgunnameComment
try update to last version 4.2I've got livefootball 4.1 plugin installed but when i goto the middle icon (soccer on satellites) I get error message "error processing data, please update liveonsat url from about & updates option and try again"
source site liveonsat keep changing its addressComment
Great Plug in mfaraj57 you are one clever dude..
Is there any way for a sad Everton supporter to edit the rss file for some news from goodison park?
Thanx again man
Ok Sussed it thx...
FYI edit the feeds.xml with your teams RSS which is located in...
/usr/lib/enigma2/python/Plugins/Extensions/LiveFootBallLast edited by redone; 13 August, 2012, 16:13.Comment
I've updated to 4.3, now i get error "Website server failed to handle your request! Check liveonsat.com from another device"
I checked liveonsat.com from PC and it loads.
In livefootball settings liveonsat url is http://liveonsat.com but the homepage of liveonsat is http://liveonsat.com/daily01.php
EDIT. It's working now
Can't get this to show up under plugins at all (have installed livesoccer1.7 in the past)
Tried both copying "enigma2-plugin-extensions-livefootball-oe2.0_4.3_all.ipk" using both DCC & Telnet
Then going to Dreambox receiver and pressing Green Button, Yellow Button, Manual Install IPK files & then installing.
I get an error message 211 and the box tells me that numerous flag.gif are already installed
When I go back to my plugins, the Livefootball plugin is nowhere to be seen
My image is Nabilosat Enigma2 Black Hole - DM800 v0.12
Any help would be appreciatedComment
