Commando 14.3 sattelite help!
  • duglish
    • Feb 2011
    • 87
    Im having trouble scanning sattelites it keeps saying transponderscan failed
    anyone got a rookie guide where I can find all the sattelites and have 28.2 as the main one?
    CHeers
  • duglish
    • Feb 2011
    • 87
    Do i need to set my longititude etc?
    • LraiZer
      • 126
      yes, if you have a motor setup. you need to enable DiSEqC 1.2 in service scan menu and then enter your lat and long in motor settings menu. turn on gotoXX and save settings. scanning and channel zapping should now auto move dish to correct sat.
      the alternative to using usals/gotoXX is to manually setup the correct sat positions in your motor table. if your motor's stored table has 28.2E at postition 1 then set the number 1 to 28.2e in the motor settings menu sat list, if 19.2E is stored in your motor postion table at position 5 then you would set the number 5 to 19.2e in the sat list in motor settings menu...etc. you can manualy drive your dish and change your stored moter table settings from the manual motor setup menu.
      • duglish
        • Feb 2011
        • 87
        thx re-flashing box now, will try in a sec and thanks for the fast reply.
        How accurate are USALS? I've heard manual is more reliable?
