newenigma picons
  • bigoz
    • 105
    newenigma picons
    anyone managed to get the picons working on the newenigma 3.2.1 image? i've tried following flipflops instructions, but cant get them visible regardless of which location i try.
  • dbsatm
    • Jun 2011
    • 21
    I put them in the folder picon then a sub folder piconHD that was already there and the sgt flip flop ones work for.me with that image :-) I'm sure that's the right folder name but if it doesn't work ill check for sure mate :-)
    • bigoz
      • 105
      found the piconhd folder you mention, but still not working when i drop them in there - could it be because i've still got the usb stick inserted which has the picons on it?
      • dbsatm
        • Jun 2011
        • 21
        It could be yeah I'm not sure, or you've changed some settings that have caused it to not work?
        I've just put RamiMAHER version 3.2.2 (snapshot 27th July) on my DM800 today and the following has got picons working:
        1. Default Image
        2. I couldn't remember the proper name of the folder (PiconHD) so I went to Blue button --> Newnigma2 Services --> Manage additional software --> online installer --> Add/Remove Picons --> added picon-hd-kabel (creates the right folder on Picons\Piconhd)
        3. Reboot enigma
        4. Copy the SgtFlipFlop picons to that PiconHD folder above and it works fine for me.
        Under Expert settings on the Newnigma2 services menu my picon location is /picons/ maybe you have put /usb/picons/ or something and it needs changing?
        Picons do work on Newnigma 2 though so maybe do a rebuild of the box if you can?
        • bigoz
          • 105
          how do you get to the expert menu that you mentioned?
          • dbsatm
            • Jun 2011
            • 21
            Blue button --> Newnigma2 Services --> System Tools --> Expert Settings
            There's also:
            Blue button --> Newnigma2 Services --> OSD Settings
            Both of those menus have settings in and mine are all defaults that come with the image. If you post your settings I'll confirm what mine are if they're different.
            • bigoz
              • 105
              There's also:
              problem i have is that i've set up the multiquick button to bring on the cooltv guide with blue button press so cant get to that menu and cant seam to disable to quickbutton
              • pento123
                • Jun 2011
                • 74
                There is a very very easy way to do this lads through TSPanel
                from memory
                Select Tunisa Sat
                PiconHD
                Astra 28.2e
                Install.
                Restart Enigma2. You're done.
                • bigoz
                  • 105
                  from memory
                  Select Tunisa Sat
                  PiconHD
                  Astra 28.2e
                  Install.
                  tried that and got loads of errors during the download saying file/directory not found for each picon, so took ages and got no where!
                  • alom5
                    • 1648
                    that's interesting, as i just done it and works fine.....only thing is they are all for flash.
                    you may have no spare flash memory and that could be the reason it has not worked.
                    maybe uninstall some other addons that you don't use and try again...
                    • numsy
                      • Nov 2010
                      • 6
                      this is how i done my picons on a dm800se original
                      blue button > newnigma2 services < system tools > expert settings
                      then edited the expert picon folder to show this
                      /media/hdd/piconHD/
                      THEN PRESS GREEN BUTTON TO SAVE
                      EXIT till you arrive at newnigma services the go into osd settings
                      go to skin picon location and change this till it shows
                      expert ( /media/hdd/piconHD/)
                      same for lcd picon location
                      EXIT till you arrive at newnigma services the go into MANAGE ADDITIONAL SERVICES
                      then into add/remove picons
                      pick any of the picons and install
                      this will put the picons in for you
                      if you want to change ie put your own picons for your sat
                      ie like sgflip
                      then go to your ftp
                      and go to the folder /media/hdd/piconHD/piconhd
                      and add all your picons
                      hope this helps you
